ever so slightly right (above). only a smidgen though
Dead Center
Slightly Left, or cooler than center
Slightly Right, or warmer than center
Hey all... In full, warmed up normal mode, where is everyone's (M30) coolant temps? Dead Center, Ever so slightly above, or every so slightly below?
Chris
Just a bit left of center. My m30 has an oil cooler, if that matters. Hippieland doesn't see big ambient temperatures.
erased due to slander
12 noon or just slightly below. Not above ever.Originally Posted by borderchris
Enjoy!
Fusion
ever so slightly right (a needle-width above) on a day above 25 degrees C (77F), but never above that. Doesn't drop below a needle to the left except during warm-up. Below 25 it likes to sit middle to half a needle left.
I think it depends on climate, but this may be because my aux fan connector is a bit dodgey. My motor is basically new, stock spec- I believe middle is where it should run unless something is wrong (It also ran in the middle prior to the rebuild, but I only get one vote... ). I'll update when I have new connections installed. Nick
ever so slightly left of centre.Our temps are even more temperate than Nick suggests
Gone but not forgotten
hmm.. mine has always been a needlehead to the right... even after a new tstatOriginally Posted by Paul in NZ
it never moves once it hits peak temp either...
yes Randell but the temps prolly have a lot to do with it.....it would be rare for Wellington to go over 20 and 25 would be max....its getting into winter now and i have had the 3 degree warning twice this week!
doesnt seem to matter what the outside temp is mine is allways a needle width to the right
kev535i south oz
RCH left of center.
1990 535i 5-sp., except for 16" M-Contours, cd deck, and clear corners, completely stock. 226k and running strong
