Results 1 to 10 of 12
Thread: "Top Tier Gas" - BMW Recommended Gas Companies???
    Jul 2004
    Montreal, Canada
    Default "Top Tier Gas" - BMW Recommended Gas Companies???
    taken from e46fanatics
    BMW has released a list of Top Tier Gas companies with "better" fuel, that will make your car run better!
    Has anyone seen this yet?
    http://www.toptiergas.com/
    ^°^ ><((({º>°°
    Wellington,New Zealand
    they shoulda done that in about 1993/4
    Gone but not forgotten
    Jul 2005
    NOR CAL
    I havent ever seen that but These companies have been saying this for a while
    "Currently, many gasoline retailers provide fuels with lower-quality additive packages that can build up deposits on fuel injectors and on intake valves."
    Same techron, v-power slogan. Thats why u always see a shell station next to an AMPM, one has cheap gas and one has good gas. right.
    Jul 2004
    Montreal, Canada
    letter from BMW
    ^°^ ><((({º>°°
    Lexington, Kentucky
    Aways use top tier gas 93 octane almost all the time. I use BP 93 when I cannot find Chevron or Shell. I also often add Fp60 or Lucas upper cyliner lubricants. I think I notice a slightly smoother engine.
    Hockinson, Washington
    I also use "top tier" gasoline. I have never filled my tank with anything other than Shell plus-grade or Shell V-power. Another fun factoid: I have filled my tank at only one station for as long as i have had the car.
    absolutly none of them stations exist with the exception of Shell, which is on a corner with rental homes and apartments so the average cost per gallon is always at least 15 cents per gallon higher then anything else. I use Mobil 93 octane and once used their 89 octane when premiul wasnt available and got 2 MPG higher and no pinging or detonation...havent experimented with it since tho. I do wonder if it works better in my car though.
    Bedford, Texas
    Good post! I always use Chrevon or now even Texaco. After I had problems with carbon buildup and other deposits in my Chrysler fuel system. Now, I would only use Top Tier gasoline retailers, and I have been trying to convince my dad to switch away from the cut-rate stations as well.
    Another good tip that was passed down to me was not to fill up when a refueling truck is there...it stirs up the dirt at the bottom of the tanks. Better to keep that junk out of your car.
    1995/BMW/540ia/mfr 09/94
    May 2006
    don't
    Hmmm... only gas available around my way is Sunoco, BP (which is slowly disappearing for some reason), Sheetz, whatever Giant Eagle sells and I think that is about it within 30 minutes of my house. Sunoco is the best I can get, so that is what I use.
    actually BP is good stuff, its refined in Canadia and thats supposed to be from the alaska and canadia crude that the US cant refine (cause they are retarded and artificially keep the costs high)
    Quote Originally Posted by uflnuceng
  1. Brake Pedal "Tapping"/"Knocking" Sound - 89 535i
    Last Post: 10-16-2007, 07:12 AM
  2. Recommended tire pressure for 17" style 5 rims?
    By NielsGalan in forum 5 Series BMW
    Last Post: 04-30-2007, 03:10 PM
  3. Recommended 18" Tyre and Spacer Sizes for E34
    By ronkovic in forum 5 Series BMW
    Last Post: 08-23-2006, 07:48 AM
  4. "Trans Program"/"Limp Mode" Redline a Engine?
    By JMI in forum 5 Series BMW
    Last Post: 06-12-2006, 10:51 PM
