Thread: how cylinders are numbered on V8 (M60) ??
    Jun 2006
    California
    Default how cylinders are numbered on V8 (M60) ??
    I have the Bentley manual and I couldn find that info
    I can only guess the number one on the front, driver side.
    Julio
    95 530i M60 engine, Manual trans.
    download this
    http://www.e38.org/e32/M60EngineSpecs.pdf
    http://www.bmwworld.com/engines/m60.htm
    Depends, if your car is RHD or LHD
    Cylinder 1 on the m60 is the right front cylinder
    Cylinder 5 is the left front
    baton rouge, loserana
    us cars it's 1234 on the right and 5678 on the left starting at the front
    PA
    Ok so then when flushing coolant www.bmwe34.net says pull drain under cyl #6... thats obviously for an l6.. wheres block plug on a V8?
    one on each side about at the 3rd cylinder back, right side easyer to get out and is usually a plug, the left side can be a bitch and the bolt is usually sloted so you only need to back it out a few turns
  1. synchronisation of banks of M70 engine cylinders
    By shogun in forum 8 Series BMW
    Last Post: 07-20-2009, 11:11 PM
  2. Running On 5 Cylinders
    By Mr Toad in forum 5 Series BMW
    Last Post: 07-15-2006, 01:50 PM
  3. M30 running on 3 Cylinders !!! help
    By grave77 in forum 5 Series BMW
    Last Post: 03-18-2006, 02:36 PM
  4. One or two cylinders not working in the morning
    Last Post: 01-09-2006, 08:44 AM
  5. Replies: 2
    Last Post: 04-19-2004, 08:21 PM
