Results 1 to 10 of 16
Thread: headgasket problem?(need help)
    May 2006
    Romania
    Default headgasket problem?(need help)
    Hello! I have a bmw 520.i 24V E34 and I think(not sure) I have problem with headgasket. I changed water pump, thermostat, cleaned the raditor, change coolant but engine overheats(sometimes). The temperature gauge will get into the middle, and stay there for few minutes and then move to the red zone but never touch it. I don't have visible warings such as:
    -Coolant in oil or viceversa
    -Mysterious loss of coolants without traces
    -Thick white smoke coming out of the tail pipe
    So, what can be?
    May 2006
    Antwerp, Belgium
    Quote Originally Posted by kosty99pjd
    So, what can be?
    Well I'm no cooling system guru, but could you tell us some more. Like: does it overheat when cruising or in idle when stopped? Did your symptoms come before or after the changes you made? Etc.
    If it redlined before those changes and you did that well: could be fan clutch.
    May 2006
    Perth Western Australia
    Probably the fan clutch but:
    Was the water pump still in one piece when you removed it?
    Have you bled the cooling system properly?
    Have you used the BMw coolant (blue) you should have!!)) ?
    hth
    Ross
    BMW parts professional
    Previous rides:
    BMW
    E12 M535i (go the dogleg!)
    E28 M535i (MMM M88!)
    E34 535i M
    MAZDA:
    RX7 S-IV T04 (440 hp ATW)
    RX7 S-I 13b bridge port
    RX4 13b peripheral port
    follow the bleeding procedure, do the aux fans come on when it is hot? Should at least come on when the AC is on.
    May 2006
    Romania
    I have the symtom before my change(so first I change my thermosta, then water pomp, then cleaned raditor but nothing).
    The temperature gauge will get in red zone in idle when stoped. When I run at speed >30-40km/h The temperature gauge goes and stay to the midle.
    May 2006
    Romania
    I have no AC on my car.
    May 2006
    Antwerp, Belgium
    Do a quick search on this forum and you'll find some threads about similar cases + some very handy diagnostic write-ups on the cooling system and the fan clutch. Once you can eliminate some possible causes and narrow things down the fix is easy.
    May 2006
    If it heats up at idle but cools down once your moving your fan clutch is buggered and needs to be replaced.
    Previous rides:
    BMW
    E34 535i M
    MAZDA:
    This is classic symptom of a bad fan clutch.
    But the fan is still there; is it working when the car heats up? If unsure test it...
  1. So, does everyone headgasket look like that?
    By infinity5 in forum 5 Series BMW
    Last Post: 05-01-2005, 02:02 AM
  2. Headgasket soon to RIP
    By GaryE in forum 5 Series BMW
    Last Post: 04-04-2005, 08:00 PM
  3. Possible Headgasket problem; need help!
    By Al Gray in forum Engine & Drivetrain
    Last Post: 04-03-2004, 11:50 PM
  4. Possible Headgasket problem; need help!
    By Al Gray in forum 5 Series BMW
  5. Is this my headgasket?
    By kick7ca in forum 5 Series BMW
    Last Post: 03-31-2004, 01:28 PM
