Here are all of the alignment specs for E34's (except for tourings, the only difference being a little more toe in with the rear wheels)
Base, Sport, M-Technic
Front:
Camber -13 min +/- 30 min, -30 min +/- 30 min, -28 min +/- 30 min
-.22 deg +/- .5 deg, -.5 deg +/- .5 deg, -.47 deg +/- .5 deg
* Maximum allowable camber deviation between sides 30 min / .5 deg *
Caster 7 deg 53 min +/- 30 m, 8 deg 8 min +/- 30 m, 8 deg 13 min +/- 30 m
wheel 10 deg 7.88 deg +/- .5 deg, 8.13 deg +/- .5 deg, 8.22 deg +/- .5 deg
* Maximum permissible caster difference between sides 30 min / .5 deg *
Caster 8 deg 8 min +/- 30 m, 8 deg 26 min +/- 30 m, 8 deg 28 min +/- 30 m
wheel 20 deg 8.13 deg +/- .5 deg, 8.43 deg +/- .5 deg, 8.47 deg +/- .5 deg
Total Toe 18 min +/- 5 min, 18 min +/- 5 min, 18 min +/- 5 min
.3 deg +/- .08 deg, .3 deg +/- .08 deg, .3 deg +/- .08 deg
Base Sport M-Technic
Rear:
Camber -2 deg 20 min +/- 30 m, -2 deg 35 min +/- 30 m, -2 deg 50 min +/- 30 m
-2.33 deg +/- .5 deg, -2.58 deg +/- .5 deg, -2.83 deg +/- .5 deg
Total Toe 25 min +/- 7 min, 28 min +/- 7 min, 21 min +/- 7 min
.23 deg +/- .12 deg, .47 deg +/- .12 deg, .35 deg +/- .12 deg
Level8Drummer
1995 540im
