Results 1 to 10 of 14
Thread: Need Help On Wiring !!! Asap !!!!
    Default Need Help On Wiring !!! Asap !!!!
    New to BMW's and just getting this project almost done. There is a single wire that is brown with a green stripe that runs infront of the timing belt cover. It has a 2 prong plug with a single wire. I can not figure out where this goes?
    ALSO the wire the goes around the spark plug wire and has a 3 prong plug where does that plug into?
    my car is a 1989 525i.
    to the front
    Jul 2004
    Quote Originally Posted by wheelerdealer
    I am guessing you are talking about crankshaft position sensor and cylinder 6 sensor. Both plugs go side by side into the main harness plastic enclosure by the fuel pressure regulator but on the passenger's side. In correct position plug wires run down.
    deleted air conditioning
    http://img81.imageshack.us/my.php?image=dfd0025jl.jpg
    Here are pictures of what I need some help on. thanks
    Jul 2004
    I apologize...
    For some reason I imagined that you had 535 not 525.
    I am shooting to start my car for the first time tonight if I get these wires figured out. I even bought a bently book for my car and that was the biggest waste of $25 I have spent so far on my car. It dont show nothing.
    Indiana
    Have you studied the wire diagrams in the back of the Bently?
    YES.
    Iam about to pull this motor and transmission and put a sbc in it.
    If someone could go pop there hood for like 5 seconds and tell me where they go or take pictures of it.
    Mar 2004
    I don't have an M20, but according to the ETM they plug into the plastic conduit that has all the fuel injector wiring. Look between injectors 1 and 2. The farthest forward connector is for the wire that goes to spark plug wire.
    Post your email and I'll send you the image from the ETM. I can't post image here since it exceeds max size I'm allowed to post.
    Paul Shovestul
  1. Will these fit my car ??? need help asap thanks
    By wheelerdealer in forum 5 Series BMW
    Last Post: 10-12-2006, 05:11 PM
  2. NEED help ASAP Stereo wiring harness 1989
    Last Post: 08-09-2006, 08:20 PM
  3. Help! asap :(
    By nuwde in forum 5 Series BMW
    Last Post: 02-13-2006, 10:12 AM
  4. In Need Of Help! Asap
    By wishihad50k in forum 5 Series BMW
    Last Post: 08-20-2004, 11:06 AM
  5. Help!!!! Asap!!
    By Mo Fo in forum 3 Series BMW
    Last Post: 06-11-2004, 08:51 AM
