might want to compare the symptoms in this bulletin to the symptoms being exhibited, maybe you should test drive it and see what it does first hand
http://plaza.ufl.edu/rroopnar/SI%20%...pter%20Cas.PDF
redline fuel injector cleaner can be obtained at pepboys (for sure) or any autozone that has the redline water wetter as well.
