i forgot to mention the cover is held on usually with #40 torx and the plug slides out when you get the cover off, you do need to remove the pump from the car
the abs pumps internal wiring sucks balls but if you are GOOD with a soldering iron you can fix it for a few bucks, when you start getting codes for valves in the pump the wiring is shot, when i say wiring i am being generous this crap is basicly some foil and plastic laminated together, which is the problem, a while back i figured out how to rewire it with real wire and have since done a **** load of them and even supply a couple shops with them
i use 22 gauge solid insulated copper wire avalable at radio shack and most electornics supply places, stranded wire works but is harder to run in the small space you have to work in, get two different colors to keep it simple and a couple foot of each should be more then enough, i run all of the solenoid wires leaving them a little long then connect them all to the plug at the same time, this is not a repare for those who haven't mastered soldering
Great stuff. I will also use it for the German E36 board with
*written by winfred
Now I need your German version for this, otherwise I claim copyright for the German version
I hope I don't have to do this anytime soon. I did swap in new plugs & change the oil yesterday, on the e36. BMW really is chincing out from the e34; there isn't much of a tool box in the e36's trunk. There is no spark plug tool, but deep sockets work fine.
erased due to slander
uhhh go for it
Originally Posted by shogun
Hey winfred,
finished the translation, look here
http://www.autotechnik-forum.de/view...hp?p=1050#1050
You now become famous in Germany too
haha, this little write up woulda been useful two weekends ago when I helped solder my friends abs pump...we just got one good working one from a junker, took it apart and started building his back up...it works now so its all good
1
Originally Posted by BigKriss
