Results 1 to 4 of 4
Thread: Ignition fuse blows after each start up.
    Jul 2005
    Default Ignition fuse blows after each start up.
    We've developed some electrical gremlins in our 95 525iT 160K. The no. 1 fuse will blow after the car is shut off. Replace the 15 amp fuse, car cranks, then after shutting off, won't start because fuse is blown. Now the gauges and wiper is off after the car starts. That is the newest symptom.
    Could my OBC be in need of replacement?
    Chip in SC
    Jul 2005
    Default Fuse blowing...touch the brakes and it's done.
    On my way home from work, after replacing the 15 amp #1 fuse, starting the engine, gauges working fine UNTIL I step on the brake pedal. Then the gauge cluster loses power and fuse blows.
    Sounds like a short. Could my rear deck wiring harness be the culprit?
    Quote Originally Posted by mossyoaks
    Chip in SC
    If hitting the brakes rusults in a blown fuse, the hinge harness would be the first place I would look.
    yes, lots of problems manifest them from the trunk harness wiring, you may be surprized at the amount of shreaded wires.
    Quote Originally Posted by joshua43214
  1. Ignition won't go to "start" position?
    Last Post: 12-18-2007, 06:13 AM
  2. Fuse #9 blows when I turn on the A/C?
    By tlp in forum 5 Series BMW
    Last Post: 01-10-2006, 04:57 PM
  3. Replies: 2
    Last Post: 11-27-2005, 07:06 PM
  4. Replies: 16
    Last Post: 10-11-2005, 09:42 PM
  5. key won't rotate in ignition switch or start car
    Last Post: 03-12-2005, 10:59 PM
