Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: Water Power!
    Default Water Power!
    The next fuel for the next generation, its been suppressed since the 70's..
    People have ended up dead over working units in America once they go to the
    Energy commission.
    Japan has been making commercial welding units for years.. On demand hydrogen and oxygen in a gas state(BROWNS GASS), what's the cost
    of water? OPEC cant stop the rain.
    The technology is relatively simple,
    FACT: ONE GAL water= 1300 GAL OF HYDROGEN, 680 GAL OF O2
    http://www.bimmer.info/~regal632/WaterFuel.wmv
    Wellington,New Zealand
    but the energy to split it comes from?
    Gone but not forgotten
    San Francisco, CA
    a neat idea but as you pointed out, old news. Hydrogen burns a lot cleaner but a combustion engine is so ridiculously inefficient that almost worthless unless your a member of green peace. Although one should gain a considerable HP increase burning straight Hydrogen. Its too bad that ford doesn’t have a stainless exhaust or ceramic coatings too...
    Im not trying to come off as some jerk saying H2 isnt the future because its the exact opposite. It is genious medium for transfering our energy but the problem has been sience the 60's, where on this earth are we going to find all that electricity?
    Electricity that can be charged back into the power source.
    Idonno, I is possible and I believe this knowledge has been suppressed.
    Quote Originally Posted by Paul in NZ
    this is the Hydrogen economy that every one has talked dreamed about for decades....Nuclear Fusion ??? is the key
    as it says, people have been killed knowing the technology. I do not have the brains to even grasp what is being done here but I believe it to be real...100km on 4 oz water.
    Default Water is not the power source, Hydrogen is, not the same. ...
    To get the hydrogen from the water requires as much energy as you will get burning it back.
    Javier
    Derbyshire, UK
    And it's based on ALIEN TECHNOLOGY that they got from the ROSWELL CRASH, the moon landing was a FAKE they filmed in HOLLYWOOD, and Elvis is STILL ALIVE and living in Lubbock, Texas. Etc.
    Damn, where'd I put my tinfoil hat? Without it, they can CONTROL MY THOUGHTS, too.
    Maryland, Virginia, D.C.
    Least Painful, least permanent: E85 Alcohol
    Most Self-Sufficient, most permanent: Zero Point Energy
    Sea of electricity harnessed via solid state hardware. http://www.wbabin.net/science/tombe3.pdf
    Most Dependent, 30 year lifespan: Element 115->116 oscillation gravity wave(not naturally occuring on earth)
    Most Suicidal: Moon god 'Cult of Death' owned oil.
    Hydrogen can be gotten from 2 electrodes placed in water with a low electric current, which will break the bonds of water. It's slow, but it works. And it can be run from solar, hydro, or wind based power. Doesn't take alot. Hydrogen is a bit rediculous to contain though. And as a technology, it isn't solid state which means it's another bandaid.
    We need to harness energy that is present everywhere and via a solid state device. Otherwise, we will end up right back here 100 years from now. Gravity.. zero point.. electrostatic.. whichever. In the interim, I would suggest alcohol. We can make all of it ourselves. After that, we can move to a more permanent solution.
    Default So, plants make better solar cells than human knowledge. ..
    Isn't it typical of nature? Better efficiency, better storing, and even more efficient consumption.
    Javier
  1. Water Reservoir Clogged, Water Pump Leaking?
    By kelhami in forum 5 Series BMW
    Last Post: 04-28-2008, 03:01 AM
  2. Small water pipe came out while doing water pump
    By merlin in forum 5 Series BMW
    Last Post: 09-27-2007, 06:11 AM
  3. Arrgh! Radio power = 0, Amp power = 0
    Last Post: 09-11-2007, 12:23 AM
  4. Replies: 2
    Last Post: 12-01-2004, 02:58 PM
  5. Replies: 8
    Last Post: 07-12-2004, 11:53 AM
