Results 1 to 10 of 17
Thread: Need info on Bosch coil 0 221 504 410...
    PA
    Default Need info on Bosch coil 0 221 504 410...
    I am trying to find out what dwell i need to run these coils to keep them from catching fire when I go full standalone - I am thinking if they're anything like the Bremi coils they will be 3.3 ms, but I don't want to guess it.
    The full part number on the coil looks like this:
    0 221 504 410
    1 748 394
    Haven't found any tech sheets for it yet, any help?
    This is the stock coil, correct?
    If you know someone with an old fashioned osciliscope, you can hook it up and measure the "dwell". Just get a set of scrap ignition wires to jumper from the coil to the plug, you do not need the #1 reference if all you are doing is watching a single firing line. I have done this for diagnosis purposes in the past with good results on DIS cars. make sure you run a smal ground wire from the coil to the head, its probably not needed on a BMW, but its best not to take risks with electronics. On the older Jags, it would blow the instrument cluster if you cranked the car with a coil ungrounded.
    Or even better, use a lab scope to check it, but not even many pros have them.
    I would be surprised if running it at anything other than stock dwell would make much diference. BMW has always been a bit tight mouthed about this type of figure, so I am not sure its published anywhere.
    PA
    Stock coil yes -
    I did find the numbers for the Bremi model, but when I looked up on some part supply websites, it says do not substitute a Bremi for a Bosch or vice versa - not sure if the dwell are different or the overall resistance, but something is different - they said its fine to replace 6 bremis with 6 bosch, but not a single one... so I think it'd be a resistance thing (want to load the ignition drivers properly across the whole ECU) but not sure. Crap this sucks.
    i swap coils and see cars with different coils all of the time, id suspect they have very close spec's from brand to brand as they all run with the same series of computers
    Jul 2004
    Stock coil yes -
    It's not resistance but "turns ratio" that affects the time of charge...
    deleted air conditioning
    just like say, the turns of wire in a coil? lol
    Quote Originally Posted by Rustam
    PA
    Too easy
    PA
    That's not my point - Bremi and Bosch have different resistance spark plug boots . I think one is 1.8k ohm and the other 1k ohm. Thus, you wouldn't mix Bremi and Bosch because it would load the ignition drivers differently. That is my theory of why they say not to mix them - the dwell has to be the same... the ECU is programmed to handle a certain dwell, it is not variable.
    I was mixing apples and oranges a bit, sorry. I only mentioned resistance since if it is incorrect it can cause the drivers to shut off.
    The plug boots are part of the secondary ignition system, so the ECU does not see them when it charges the coil. The time it takes for the primary windings to saturate will remain the same regardless of how much resistance there is in the secondary.
    I should have said that any coil that is listed as a replacement part will have the correct properties for both the safe operation of the ECU and required dwell for proper operation of the coil itself.
    PA
    Quote Originally Posted by joshua43214
    That's what I was thinking Joshua - so if I found a Bremi coil dwell time is 3.3ms, it would be "safe" to assume that a Bosch (an OEM replacement) should have the same 3.3 ms dwell time?
  1. Replies: 2
    Last Post: 12-22-2010, 06:47 PM
  2. Bosch coil celebrity meltdown.........
    By Dave M in forum 5 Series BMW
    Last Post: 12-20-2008, 09:14 PM
  3. I need info some steering wheel info
    By pmlmotorsports in forum 5 Series BMW
    Last Post: 05-06-2005, 08:25 AM
  4. Replies: 0
    Last Post: 11-07-2004, 10:02 PM
  5. Replies: 22
    Last Post: 04-26-2004, 11:23 AM
