Results 1 to 10 of 13
Thread: NEED HELP ASAP ~what is this called?
    Default NEED HELP ASAP ~what is this called?
    I bought a project 525i and putting it all back together and found out this has a crack in it and I want to order another one.
    What I need is that plastic peice at the end of the 2 rubber hoses.
    Where is the best place to order parts and the cheapest. lol
    All autozone and oreillys sell are JUNK.
    Houston, TX
    Have you checked RealOEM?
    Mar 2004
    Quote Originally Posted by mikell
    RealOEM will let you find the part number...
    http://www.realoem.com/bmw
    Autohuas (Arizona) http://www.autohausaz.com/
    and BMA autoparts http://catalog.bmaparts.com/ are two suppliers that have done me well.
    Scott
    07 525i 22K, 07 328xi (41K)
    I believe that's the temperature sensor that hooks to your HFM from the airbox. It controls the coolant flow to it.
    But I'm sure someone will correct me if I'm wrong.
    Check bimmerparts.com for it. They tend to have pretty good prices, and quick shipping.
    what is that part called?
    Derbyshire, UK
    From your description, I can't tell which part you're referring to. Do you mean the non return valve, the air pump, or the rubber boot?
    The hard plastic valve thing at the end of the two rubber hoses.
    Derbyshire, UK
    Still not clear what you're referring to. I've labelled your image:
    Hope this helps...
    THANKS it is the non return valve I am needing.
    Do you have to run them?
    Is there a way to bypass it?
    There is 2 wires that run across my timing belt cover. One wire with a 2 prong plug that runs across the timing belt cover and goes to nothing. The wire is green with a brownish stripe. The other wire is my crank sensor.
    Deal with my car is that I bought it with no head. The timing belt broke and broke the rocker arms and bent the shafts. The guy I bought it from was going to junk it. It is from Florida and is rust and dent free. The inside is pretty much perfect too. So I bought a head off ebay and hole topend kit from bmaparts.com. They seem to be cheap on there prices. I am happy with it. I am just hope'n the bottom is tight and isnt a nocker. lol This is my first BMW. So I am crossing my fingers everything is going to be ok. I am used to building SBC & BBC stuff. I was always told that BMW are super hard to work on. But so far everything was been easier than anything else I have worked on.
    Derbyshire, UK
    Quote Originally Posted by wheelerdealer
    BMW put it in there for a reason. I've not tried eliminating it, but I suspect its absence would result either in a brake servo that doesn't work properly or an engine that stalls when you brake. Maybe both. Maybe other things go badly, too, or instead. Dunno. I'm guessing here. Bypass it and see what happens.
    Is anything connected to the oil pressure sensor under the right side engine mount? What about the A/C compressor.
    Deal with my car is that I bought it with no head. The timing belt broke and broke the rocker arms and bent the shafts. The guy I bought it from was going to junk it. ...
    Mine was a similar case. See http://shark.armchair.mb.ca/~dave/525i for the whole story.
  1. What is this panel called
    Last Post: 07-17-2008, 08:11 PM
  2. What are these called?
    By Calico_NC in forum 5 Series BMW
    Last Post: 06-14-2006, 01:57 PM
  3. Why has no one called BMW out?
    By zhandax in forum 5 Series BMW
    Last Post: 01-12-2006, 12:15 PM
  4. I just called for a price on the X3 3.0.....
    Last Post: 10-01-2004, 06:03 PM
  5. whats yours called??
    By Ian w in forum 5 Series BMW
    Last Post: 07-06-2004, 01:17 PM
