make the rear end feel real squirrelly, check the dog bones, stabilizer links and rear end oil while you back there.
The rear subframe bushings are totally shot on my 525i. I have known this since the day I bought the car.. been thinking seriously about replacing them soon. I seen the thread on the sawzaw method and that is the rout I’ll go.
Anyway, can the rear mounts seriously effect the stability of the car? I ask this because the car is a real handful sometimes. Hard to tell but it feels like the rear end is tracking and steering the car. Especially when I pass a semi truck.
Of course the front end could be shot too. I wont touch the front until the rear is fixed. One problem at a time.
BTW garage sale season is starting… For the best deals.. don’t drive up in a black BMW 5 series.
SOLD!
When my rear subframe bushings were bad, the rear wheels often wanted to overtake the front wheels. Wet or dry. Once the rear bushings were fixed, I couldn't cause the rear wheels to overtake the front wheels (I lost my nerve before the rears wheels lost grip). Good luck!
Isn't it funny how people see the 5 and think you must have paid the original sticker price for it... even though it's 15 years old. I'm always explaining myself to customers (for other people I like to let them think I'm loaded!)Originally Posted by fujioko
Robin
72 Chevy K10
01 E39 M5
Yes, bad subframe bushing will cause instability, especially at highway speeds. You might fel the rear end floating around on slight curves.
my bushings were bad, but I simply used Bruno's delrin insert for the rear - it absorbs the slack.
$25, easy install
Might be worth trying before you do the big job.
http://www.racingking.net/Canada/scr...?idProduct=693
^°^ ><((({º>°°
I have delrin inserts. Seem to help with up/down motions and stiffen in corners. No apparent increase in harshness. Even so, if the bushings are worn rather bad, there may be, IMO, some lateral movemnt that will cause self steering.
FYI, I have some wandering that I am trying to eliminate. I have replaceed front struts, rear dogbones, front swaybar links. Yesterday I replaced the front upper thrusts arms with Lemforder/750i bushings. Have not been on the road yet, we shall see
