amazing how quick we can do these after several shock replacements...
Originally Posted by Anthony (M5 in Calgary)
So now I get to tear into my right front strut for hopefully the last time. What a way to spend a nice spring morning...
Anthony
03/64 production
Indeed. However, unlike your springs, mine require the use of the "widowmaker" spring compressor (screw type). I'm always very nervous about leaving the spring with the compressor on having seen what happens when they slip.Originally Posted by 632 Regal
Anthony
03/64 production
it's still downright annoying to tear in to something over and over again....
Been thinking about Koni's for the 535iT and the M5, haven't been as anxious lately due to the various reports of failing ones.
heh. At least it's not the back and you have to tear down the seats I'm holding back on replacing my Bilstein HDs with Konis for this very reason...
Normally you'd be correct, but I'm also changing out my rear SLS bombs and reverting to the OE rear springs. The back seat has to come out - maybe not this weekend though. We'll see how much energy I have after hitting the bar tonight.Originally Posted by Qube
Anthony
03/64 production
ahhh but with the new sachs there is a top limit spring so I "will" have to use them damn things. Im inspecting tonight looking for the shimmy facter. The bushings look fine so im going to lift it with stands and see if somethings torn, has to be something going on under there.
