Results 1 to 3 of 3
Thread: Ghanging code-plug on instrument cluster
    Jul 2005
    Belgrade, Serbia
    Default Ghanging code-plug on instrument cluster
    My instrument cluster on 1992. 520i with digital display under speedometer is slowly going bad, speedo and revcounter are working fine, than they're not, tried to fix it few times, and I think the only solution is to change the whole thing and solve the problem.
    The car has only 150500 km on display (around 92300 miles), and I want to preserve that as a value of this car. If I change cluster, I get another mileage,probably with much more Km, because I have to buy a used one.
    I was thinking-the code plug preserves mileage and oddometer info. If I change instrument cluster, but maybe plug in my old code plug, will it work with it and do I get my mileage back with new cluster?
    It would be great, if it works.
    BAKSA
    BMW 520i, M50 24V
    1992, A/C, ABS, leather,M-aerodynamic pack,165000 km
    If the code plug in the new cluster is the same, then it should work to switch plug into the new cluster.
    But the dealer can also reprogramm it for you. Because there are much more data than only the km/miles in the chip, maybe this helps
    http://bmwe32.masscom.net/johan/299960/299960.html
    Houston, TX
    Have you considered changing the capacitors? Do a search, the subject has been much discussed in this forum. www.bmwe34.net also has instructions.
  1. coding plug faulty on instrument cluster
    By mystic_525_tds in forum 5 Series BMW
    Last Post: 04-27-2008, 04:16 PM
  2. I need a U.S. version cluster code plug/chip
    Last Post: 03-28-2008, 10:18 AM
  3. e30 instrument cluster
    By Mendozart in forum 5 Series BMW
    Last Post: 07-24-2006, 11:11 AM
  4. Replies: 17
    Last Post: 07-08-2005, 10:05 PM
  5. Replies: 0
    Last Post: 05-05-2004, 07:38 PM
