Where do I read about the Shogun Reset?
wow!!! What a difference!
I have heard about it from time-to-time but never really thought it would make such a difference!
The engine is more responsive! idle is smoother! power delivery is more linear!
the engine has stopped ticking and runs quieter, I contribute this to the injectors firing in the correct order now.
To anyone who is having symptons of valve misadjustment with properly adjusted valves should try this.
I just can't believe the difference this made! My car is literally like a different car! I can finally think about an E.A.T. chip!
thanks Shogun!
89 535i/5
90 535ia 158k
90 Infiniti Q45 (sold)
91 Sho (sold)
94 530i/5 (sold)
95 855 T5 @15psi boost
it will even clear up small dents and paint chips too.
I found it...much searching...cant wait to see the paint chips go away....
Now, this has got me EXTREMELYcurious. What is the Shogun reset and where can you read about it?
You should search. It's on this main page on how to do it. But anyway, here it is.
1. Disconnect the battery.
2. Turn the key to postion II (2).
3. Using a pole or screw driver, "short" the two battery cables. Just attach them to the screw driver. I think you need to do this for 10 minutes?
4. Re-connect battery.
Car: BMW 525iA.
Engine: M20.
Trans: Auto.
Year: 1990.
if there's something wrong with your engine setup it won't last sorry to spoil the fun but I recognize the euphoria As the DME is adjusting over (a short) time you'll end up with the same annoying symptomps like rough idle again. Time to do some real troubleshooting skills (and use this great forum) ...
Cheers,
John
Ya, however doing this reset will rule out one less thing to think of what it could be. But in the end, you're right.
Car: BMW 525iA.
Engine: M20.
Trans: Auto.
Year: 1990.
Could you let us know if it's still as smooth a day later?
