Results 1 to 10 of 17
Thread: Floppy arm rest
    Default Floppy arm rest
    I'm new to your forum and posted a cooling question a while back that garnered intelligent responses that happened to concur with my own astute diagnosis. Another plastic wasserpumpen impeller failure. This one just had a radial crack that caused it to slip on the shaft.
    Before I tear apart about a hundred times more stuff than I need to as to learn how it's built, who will share with me what breaks in the armrests to make them fall down? And where did Fritz hide the fasteners?
    Also I just replaced my aux. cooling fan as it was seized, I've saved the fan blade and it's shroud because I thought some one could use it if theirs was collission damaged but with a good motor. It's free so speak up if you can use it.
    Honolulu
    Default Fritz hid the bolts
    on the inside of the seat.
    remove the back panel..it un clips and you should be able the access the bolt that holds the armrest on.
    baton rouge, loserana
    double check that the pin hasn't started to slip out that holds the arm rest to the bracket, you can see it at the crack between the seat and arm rest and when it backs about half way out it can get floppy
    Welcome aboard Ross!
    The plastic impellor proly went as the cooling system got hotter than normal over quite a few cycles due to the thermo fan being dead... funny how one thing leads to another... one learns to take care of such dependencies on these cars- not doing so can be costly.
    You did do the thermostat and use BMW coolblue (OE) coolant as well didn't you? It is an absolute must, jic you don't know. Post some pics when you can and let us know how you go with your new friend... Nick
    Quote Originally Posted by genphreak
    why is this coolant so special?
    Honolulu
    Default cause it's $20 a jug
    and it's one of few that won't dissolve the head gasket or corrode the mixed metal cooling system.
    By mixed metal do you mean ferrous and aluminum or some friggin' exotic stuff. So what are the head gaskets made of,marzipan? Is there really something special. I've used the nice green stuff the neighbors dog likes to lick from the driveway forever including lots of BMWs without ill effect. This'95 m50 is the most current of the bunch. Has something changed? I can certainly change it out but would like to understand why.
    Honolulu
    Default Correct-a -mundo
    ferrous and aluminum metals
    and yes the head gaskets are made of that nasty almond butter crap.
    So what's wrong with the green stuff?
    Honolulu
    Default Watch out...you'll bring in a
    whole heard of posts now.
    Coolant and oil threads turn nasty sooner or later.
    It has to do with phosphate, and silica content.
  1. Head Rest
    By SilverFive90 in forum 3 Series BMW
    Last Post: 06-23-2006, 06:19 PM
  2. Head rest not moving!!!!!!
    By Calico_NC in forum 5 Series BMW
    Last Post: 05-21-2006, 08:24 PM
  3. Arm rest repair help
    By Springfield1952 in forum 5 Series BMW
    Last Post: 12-20-2005, 04:25 PM
  4. Replies: 3
    Last Post: 04-28-2004, 12:27 PM
