the lowers last a lot longer as most of the abuse is taken by the uppers, when you see/feel slop in the ball joint while shaking the wheel it's toast
How often do lower control arms fail/need replacement? Also how do you tell?
I sort of need to quickly know since I am planning to replace my upper thrust arms with lemforder arms and 750i bushings next week and I may do so myself and need to place an order to BMA first thing monday morning.
BTW, my 95 525i has aluminum lower control arms which have never been replaced. I understand that some 525is have steel. Even so, I understand they can be replaced with the steel arms on any model.
TIA
It's a good idea to get the upgraded 750il ball joints.Originally Posted by Russell
[2004 BMW 330i 225HP Sports Package, Steptronic Trans, Xenon Adaptive Lights
Originally Posted by Speeder 553
Bushings - not ball joints.
Originally Posted by Jon K
Right, bushings.
That's the plan!
that's on the upper control arms, the lowers are fine as is and generally last twice to three times as long as the uppers
