Originally Posted by
Montreal525
My OBC warning chimes in everytime the outside temp. hits 3 degrees Celcius. Can you change it or is it a factory setting. With all that's happened in the last 2 months, every time I hear the warning chime, my heart stops....
I don't have an owner's manual and it's not covered in the Bentley. I've played with it to see if I could be so lucky as to turn it off but no luck...Since the outside temp. this time of year is around 3, espicially in the evening, the damn thing keeps going off and it's getting a bit annoying...
Jeff
The gong is quite loud and cannot be "programmed" away. You could just un-plug the gong but I wouldn't. I muffled mine using some of the ex's makeup removing pads cut to fit between the gong module and its grille. 3 thick works pretty well - you can still hear it, but it doesn't give you a heart attack.
Anthony
03/64 production
