Results 1 to 5 of 5
Thread: Prob with rear window weather stripping, pic inside
    PA
    Default Prob with rear window weather stripping, pic inside
    I think in the heat the other day when rolling the window down (it hadnt been opened in about 3 weeks) it was kind of stuck to the glass or something and pulled it... now I have it sticking out a little bit and it looks horrible. It's not leaking because the window goes above it, but I need to fix it asap.
    What do you people think?
    euww. Could only suggest contact adhesive once the surfaces inside are clean with alcohol and both pieces surfaces are tacky.
    Otherwise, trim the offending piece and be done with it.
    Not 100% clear what the problem is..however I've had some similar problems with window seals. It seems that it's usually something is no longer connected/clipped/held right combined with sticky rubber.
    Find out what's come unclippped and also work the rubber tracks with some silicon spray.
    Bellevue WA
    86 Porsche 951 - Track Toy
    Apr 2004
    Reston Va
    I just noticed I have the same problem! same issue it looks like the tinting stuck to it and it pulled out. Any help would be great! - JT
    Johntee540
    1994 540/6 Black - Tan - 199k
    Cardomain Site: http://www.cardomain.com/ride/737181/1
    Razor blade, clean the track from sticky things as mentioned.
  1. anyone with the a4s 310r suffer with stripping bolts?
    Last Post: 03-04-2007, 06:04 PM
  2. reattach inside rear view mirror
    By Pepperbare in forum 5 Series BMW
    Last Post: 03-25-2005, 09:09 PM
  3. Inside rear tire wear with H&R Springs - help needed!
    Last Post: 02-03-2005, 11:21 PM
  4. rear window weather stipping/92 e36
    By caster in forum 3 Series BMW
    Last Post: 10-09-2004, 03:53 AM
