Sending you an email @ comcast.
best, whit
Ok so I am in there looking around and Javier said a bunch of stuff but I honestly can't even get the damned cover off the relay box... additionally, none of the relays are marked as to what they do or what they are. I really need +12v that comes on and off with the car from under the rear seat... someone please help.
Jon
best, whit
for 1992 E34. Pin 86 of wiper relay is fed with "Hot in Accy. Run and Start" from fuse F1 in the front fuse box, so there is a Violet/Yellow wire running from fuse F1 to rear seat. If you can not go under relay socket and tap that wire, just plug in the relay socket hole corresponding to pin 86 a wire, and then plug relay over. 200 mA is insignificant load so should work fine.
Javier
