Where did you get the plastic rings????Originally Posted by Speeder 553
I've had the 45 - 55 mph shakes forever, better and worse at times. Have had my tires balanced 3x times in the past few months with no effect. Just had my tires/wheels (lug centric) balanced on a 9700 Hunter with Roadforce and put plastic hub rings in and the ride is smooth as silk now. I think the X factors were the Roadforce and the plastic hub rings. Now there is 0 vibration at all speeds!
[2004 BMW 330i 225HP Sports Package, Steptronic Trans, Xenon Adaptive Lights
I can supply you the rings if you wish....$22 delivered to lower 48 states. Please advise. HTH
Originally Posted by E34 530
1995 540iM Alpine White/ Lt Silver Grey 84k
1992 535iM Black/Lt Silver Grey 132k
1990 535iM Glacier Blue/Blue 206k
I need some new plastic rings...haha
also need a paint code.
www.KaRealtySF.com
$22 is a good deal. They are really hard to find. Everyone has the metal ones but they band to the hub and don't do the job. My mech had a set I got for the same price but only one in stock so I would get them from Pmlmotorsports.Originally Posted by pmlmotorsports
so your schnitzers are 74mm hub ID?
Gone but not forgotten
So what's the problem with the metal ones?
They are replicas at 74.1Originally Posted by Paul in NZ
They band on the hubs. That said, not certin if it was the plastic rings or the Roadforce that really did the trick in smoothing out my ride. All I can say for sure is that I have NO more shimmy or vibration at all!!!!Originally Posted by onewhippedpuppy
This was the first time that my tires/wheels were balanced lug centric vs. hub centric on the Hunter with Roadforce and it did the job where all the other static balancing failed.Originally Posted by Speeder 553
