Originally Posted by
Jon K
Additionally, I took the circlip off the post that holds on the longer of the two chain guides...
I didn't use much force at all, but it seems like the post that holds the circlip and guide seems to be bent??? Is this normal? I cannot find any indication of bending on the guide - this is afterall just the timing chain guide, there cannot be THAT much
pressure to bend a rod like that.. what's the deal?
Is that work in progress or you already have the problem solved. The timing chain guide hinge is bent. I don't know how you can bend it back. I had the impression it was threaded. You may be able to remove it and get one new.
'01 540it, 6/01
'03 325i 5 speed, 9/02
'10 535ix. 9/09
'10 mini 6 speed
'15 mini countryman 6 speed
