Fuel problem, but where?! the new fuel filter is still bone dry (no diesel getting to it) could the fuel pump have coincidentally packed up? Not 100% on the tds engine (previously had saab petrol turbos)
hi paul,
i have a citroen pickup truck with a diesel motor -- same 4-cyl 1.9 motor that powered the peugeot 504 diesel wagons -- and although i cannot tell you WHY this is from a technical standpoint, i have been warned many times by fellow h-van owners in france **never** to run out of fuel completely. as i understand it, you can run dry with a petrol setup and with new fuel in the tank, the pump simply pushes air until fuel hits the carby or the injectors, and off you go! but with a diesel, i don;t know if it's a question of "losing its prime" or what, but apparently once the stream of diesel fuel ends, replaced by air, something more serious has to go on in the shop before it'll run again.
i do not pretend to know anything about this from a mechanic's standpoint, but thought i would at least pass along those warnings in case they make sense to you or anyone else.
bruce
1992 525iT
1976 Citroen HY-IN2 H-van pickup
1969.5 DS21 parts car
