Results 1 to 8 of 8
Thread: indicators and main beam switch
    Default indicators and main beam switch
    recently bought a 94' 520i all in great order bar a tiny fault.
    when headlamps are on if i attempt to use the indicators this can turn on main beam. also the main beam doesnt stay on but i can flash with it.
    i have had three e34s before but this is the 1st electrical fault ive had. has anyone any ideas where i should start to repair this?
    Aug 2005
    Toronto
    I have a similar problem. Don't know what it's about. I suspect I need a new column stalk to solve it.
    Jay Lebo - Toronto, Canada
    1990 BMW 535i
    5-speed conversion
    Lightened flywheel
    Sachs Suspension Kit
    E.A.T. Chip
    Jul 2004
    Kernersville, NC
    I have the same problem, but only when signalling right-hand turns. I was thinking about taking off the switch & cleaning it. I am sure that after 11.5 years there is a bit of dust in there.
    '95 540iA ~212k
    Aug 2005
    Toronto
    For me it's only left turns.
    1990 BMW 535i
    5-speed conversion
    Lightened flywheel
    E.A.T. Chip
    I know this sounds really silly, but check that all the rear bulbs are both installed properly and are the correct bulb. The most bizaar lighting problems can occur from incorrect bulbs or improper installation.
    Hockinson, Washington
    use emery cloth or fine sandpaper on the contacts, they could be corroded.
    yep I had the same thing on my e28 535- same stalk. Replaced the (perfect looking stalk) and it solved the problem. If it comes apart and you can clean those contacts I'm sure it'd do the same thing. This fix is common enough to be on Bruno's site...
    indicator stalk seems the best place to start then. i have an old 518i (91) ill try the stalk out of it, if cleaning the existing one doesnt do the trick.
    some kids broke into the 520i there recently so i have to replace the steering column cover and check why the ignition barrel doesnt click back by itself when the engine starts, so probably best to do it all at once.
  1. How to remove main beam bulb holder?
    By skeggysteve in forum 5 Series BMW
    Last Post: 01-23-2007, 04:43 PM
  2. Replacing front indicators'
    By montsta56 nz in forum 5 Series BMW
    Last Post: 01-09-2007, 10:13 AM
  3. Intermittent main beam headlights
    By tattoo93 in forum 5 Series BMW
    Last Post: 11-05-2005, 02:37 PM
  4. main light switch on dashboard replacement E34
    By tibbe in forum 5 Series BMW
    Last Post: 11-05-2005, 07:05 AM
  5. Green light Indicators?
    By realness in forum 5 Series BMW
    Last Post: 10-03-2005, 09:37 AM
