yes, jack the car up, place a pipe wrench around the collar nut and turn it, need a pipe on the wrench to get it to turn. You need to really crank this thing to get it tight. No need to remover the wheel/tire as the way the springs sit you can get enough room to tighten but not loosen...in at least my case with the eibach springs.
Originally Posted by
mikell
Whit - thanks for this info for the lurker here - so, if I tighten the collar nut, that should cure a banging on that side when an impact is encountered?
Can this be accessed without removing the spring?
Sorry to hijack the thread, but this has been bugging me.
Mike
