Results 1 to 3 of 3
Thread: Valve Adjustment on 535i M30????HELP! Questions?
    Greg Guest
    Default Valve Adjustment on 535i M30????HELP! Questions?
    • How often should valve adj be done on 1990 535i. I had head gasket replaced about 25K miles ago. Is that usually done when head gasket is replaced?
    • Are there symptoms that valve adj needs to be done?
    • How much can I expect to pay a good indy shop to do valve adj??
    • Car is running great...should I worry? I've had car for about last 60K miles. Other than head gasket, nothing major done.
    Thanks guys!
    Greg
    1990 535i, 204K miles
    Evanston, IL
    Default I was told...
    ... every 30,000 miles but please let an expert contradict me.
    in a sexy house
    Default Maintenance interval is every 15K miles, though
    I generally do mine every 10 or so. If you haven't replaced the oil spray bar bolts with the new loctite-ed bolts, it's a good time to do it, or at least check that the bolts are tight (only about 10ft-lbs, I think the spec is ~80 in-lbs?).
    Take a crack at it yourself - it's really a peice of cake--
    BMWe34.net Link--
    Quote Originally Posted by Greg
    Thanks guys!
    Greg
  1. M20 Valve Adjustment...
    By TheEndIsNear in forum 5 Series BMW
    Last Post: 08-28-2006, 02:59 PM
  2. valve adjustment
    By kevind89e34 in forum 5 Series BMW
    Last Post: 05-25-2006, 10:07 AM
  3. Valve Adjustment Order
    By athflying79 in forum 5 Series BMW
    Last Post: 03-19-2006, 01:21 PM
  4. valve adjustment???
    By xphilter in forum 5 Series BMW
    Last Post: 09-21-2005, 06:03 PM
  5. Valve adjustment tricks--535i variety
    By Bart in forum Engine & Drivetrain
    Last Post: 04-26-2004, 01:50 PM
