I have a 1996 750 IL. Recently I noticed the right side high beam was on after I parked the car and shut off the engine. The light switch is off. Playing around with the light switch or the high beam switch would not make it go out. The only way to shut off the lamp was to physically disconnect the wire from the high beam bulb.
Any one seen this weird phenomenon and know what the cause may be. Any help is appreciaited. Could it be a bad high beam switch or the headlight panel switch or possibly be some relay.
