Yesturday I was driving home from work and tried to roll the rear passenger windows down (right side). To my surprise it wouldn't budge, which I found strange because it was working earlier in the day. When I got home I got to looking at it and when you hit the switch to roll the window up/down I can hear the motor in the front window power up, kind of like the sound you get when the window is up and you keep trying to close it. Well, I got to looking last night and was curious if the door panel removal procedure is more or less the same as the procedure found on
http://www.bmwe34.net. The panel is basically the same, minus the speaker. Am I right in assuming it is the same procedure? Also, what would you guess is the reason for the window all of a sudden not working?
I figure since I will be digging into my doors this weekend I might as well take the driver's door panel off and fix the lock actuator which hasn't worked since the first time I unlocked the car. Can't expect too much from a 12 year old car right
Any help you guys can offer is greatly appreciated.
