So here's the deal. I'm just going to assume my car hasn't had much maintenance since it crossed 100k. The previous owner owns a "quicklube" My car was the loaner for when he ****ed up their car for any particular reason. It wasn't very well respected. My vanity mirrors won't open in the winter because the gum somebody shoved in them has them frozen. (they work great after sitting in a hot parking lot in the summer!) When I first bought it there was some odd hard substance along the bottom on the rear view mirror. I thought it was glue to hold the mirror or something, except it smelled minty....(#@$ing gum. Anyway, the guy said he had the car for sale because nobody respected it. Well after taking it to the car wash yesterday (I had been putting it off for quite a while...shameshame
)I realized again what a nice looking car it is. So anyway, I want to compile a list of things to do to it since the warmer months are on their way. I'm going to try to do things in order of importance.
1. What all fluids/filters should I change? I have the green coolant but it isn't even 6 months old from doing my timing chain. About 3-4 quarts of brownish (if I recall correctly) tranny fluid came out when we broke the coolant lines doing the chain. I squeezed in some fresh synthetic. I (I hope that wasn't bad) I think a drain/filter replacement is in order. I assume doing a brake system flush would be a good idea? I replaced my front calipers when I got the car since they froze up on the way home from buying it.
2. The front end of my car is getting extremely noisy when I come down my gravel driveway or fail to outmaneuver #$(#$ing potholes. My steering wheel doesn't bounce back and forth but I can tell my front tires do. From reading other posts and Bruno’s site I assume these are control arms? I like to get one of those kits (not fcq or whatever) and replace everything. I replaced the center tie rod/drag link from AutoZone (unknowing of shitty parts) when I first got it, I remember in size it compared to the one that was on there as far as thickness and the ball joints on the end looked nicely sized.
3. The bottoms of my doors are starting to rust. The back corner of the front doors and back corner of the drivers passenger door. I think the best thing to do is buy all new trim, rip off the old, sandblast/rust convert/prime/paint from the middle (not sure of the name) down? My next question is where’s a good place to buy paint? I have a pretty nice pro paint gun I picked up from some moron at a garage sale. I checked the local car quest and they can get me everything I need with a quart of paint for like 150ish...I think that’s DuPont paint.
4. My door seals on the back doors have stretched away. (the ones on the door frame, not the door) I have cut them on the bottom underneath the sill/cover to push them back on but I still have to periodically do this. You think I could use some goop and glue them down? I'm not sure how pricey it is to replace them.
5. From what I can tell my hydraulic lifters chatter like
on a cold start. My dad has suggested I install a button to break the fuel pump relay, crank the car for a few seconds to let the oil pressure come up then release the button so the car starts with decent pressure. We've also considered
http://www.streetortrack.com/preoilerunits.asp
6. I don't think there is a #6 for now. Any help/suggestions/criticisms is appreciated, thanks!
NovceGuru
