Results 1 to 10 of 11
Thread: M60 540i Injector Install Question
    Tampa Bay, Florida, USA
    Default M60 540i Injector Install Question
    I started to install injectors and they didn't fit exactly between the fuel rail and the manifold.
    If I use the lock clips, they do not reach down far enough to seat in the manifold.
    Conversely, when I seat them in the manifold, I cannot lock them in place with the clips.
    On the left: the injector is firmly seated in the manifold, locking clip is not installed because the groove won't line up.
    On the right: the locking clip in place but the injector not seated as far in as the injector on the left. Is there enough of a seal here?
    The fuel rail is torqued in place for the shot. Left injector can be moved vertically.
    I had sent them off to be refurbed and am wondering if they got swapped with a different set.
    Thanks to 632Regal for giving me advice online while I was trying to figure this out... and I still haven't!
    Ramon
    1994 540iA Nikasil EAT Chip
    Tampa Bay, Florida USA
    PA
    Double check the fuel rail installation. I know you said its seated right but obviously not. I had issues getting my injectors to sit perfectly again. Those are bosch injectors, they WILL fit... they don't make that injector in various size, they will fit.
    Your fuel rail is not all the way down. Its really easy for a stray wire to get under something. Also all 8 will kinda go in at once, there is not alot of flex, if one injector is not all the way in, it will hold the others up.
    BTW, I always clip all the injectors onto the rail on the bench, then put the entire assembly into the car. Lightly lubbing the O-rings and injector holes with gasoline will actualy help assembly, or you can use O2 safe silicone as long as you don't tell any one and start up a controversy(I use gasoline). On stubborn injectors I very very lightly tap the rail with a very light leather mallet, the idea is to jiggle them in, not to hammer them in.
    Jon,
    I'll go over the assembly again. The manifold is out of the car on thebench.
    Ramon
    Default Ramon, also the only thing that bmw recomends to
    lubricate the orings is either vaseline or 90weight gear oil
    Quote Originally Posted by MBXB
    Jon,
    Default Fuel Rail Setup
    Josh, I assembled them the same way; on bench. The fuel rail is all the way down; the mounting brackets are flat against the pad and lined up on teh bolt holes.. The injectors slid right into place, but are not seating all the way.
    How far in should the injectors be seated?
    I'll give it another shot and start from scratch.
    Quote Originally Posted by joshua43214
    Ramon
    Default 90 Wt
    I'll try that. I used 20-50.
    Ramon
    Meridian, ID
    Just a thought, did you use new 0-rings. If they are Bosch 0-rings they may be too small. BMW 0-rings are slightly, but perceptable thicker around. Makes a difference.
    Mike Holbrook
    Meridian, Idaho
    Mike,
    I had the injectors refurbed and new O-rings were installed. I compared them to the old rings and they are identical.
    Ramon
    you mentioned the manifold being on the bench, your trying to get the fuel rail on but is the manifold all bolted in? If not it will be raised from the new gaskets...just guessin at this point
  1. Need urgent help with fuel injector install!
    By J.DeFeo in forum 5 Series BMW
    Last Post: 05-31-2007, 04:18 PM
  2. Injector Question - What's missing?
    By Kobe Diesel in forum 5 Series BMW
    Last Post: 01-09-2007, 01:24 PM
  3. M60 540i Injector Replacements
    By MBXB in forum 5 Series BMW
    Last Post: 03-06-2006, 02:28 AM
  4. Injector question
    By Mr. BILL in forum 5 Series BMW
    Last Post: 09-28-2004, 07:49 PM
  5. is there a larger injector for the my 95' 540i/a
    Last Post: 02-17-2004, 05:25 PM
