Results 1 to 10 of 15
Thread: ((o:_:o)) dOg bOnes?
    Default ((o:_:o)) dOg bOnes?
    Got a heavy clunk sound, kinda like somethings loose but its all good. Dogbones rubber looks trashed but I dont get the normal car wandering symptoms.
    Do these things make niose when there shot?
    Apr 2004
    Reston Va
    Mine did! no wander but really random clunking not directly associated with anything. It made me looking for the noise. Best / Cheapest repair made to date. Tightened and quieted everything right up - JT
    Johntee540
    1994 540/6 Black - Tan - 199k
    Cardomain Site: http://www.cardomain.com/ride/737181/1
    thanks for the input, last year the rubber looked fine, today they look real worn.
    as far as I can recall these are easy to replace, ant tricks to make it easier?
    Quote Originally Posted by Johntee540
    Nope, they easy. Only trick is push real hard to get the new ones over the end of the sway.
    Dave M
    Hockinson, Washington
    Dave, im confused, are you talking about the sway bar links or the dogbones?
    Dogbones. Sorry about the pic size. The rear sway / dogbone is a tight fit. lube it up with something and push
    Dave M
    my bad...apples and oranges.
    I mean these things: 33321126476 #6 in the pic: This is what I thought dogbones were, the sway bar parts are tight as can be.
    Thats what i thought dogbones are too...
    Apr 2004
    Reston Va
    It couldnt be easier. I used a box end on the top bolt and socket/ratchet on the bottom bolt of the frame side Bolts. think the hardest part of the job is getting the car jacked up on stands - JT
    Johntee540
    Sep 2005
    Goulburn Australia
    These are the ones you're talking about aren't they. I've recently done mine and found them quite a nuisance but not that difficult. I found getting the right hand side one harder to get lined up than the left (exhaust) side. They are pliable (the rubbers not the arms) and you will have to line them up by manipulating the rubbers. Also be sure to check which way up they go and where the washers go by remembering how the old ones came out Good luck. It took me about 1.5 hrs to do with basic tools. One final thing. They DO NOT need to be torqued under load.
    Cheers
    Wingman
    '89 525i/A Exec 193000kms
    '94 Subaru Liberty AWD Wagon
    Looking for Merc 300TE
    NSW, Australia
  1. "Dog Bones"! Rear Pitman Arms
    By helm in forum 5 Series BMW
    Last Post: 10-06-2005, 01:21 PM
  2. Need Torque Values For Rear Dog Bones
    By Pwr2spare in forum 5 Series BMW
    Last Post: 11-24-2004, 07:03 AM
  3. How can you tell dog bones are worn?
    Last Post: 06-03-2004, 05:20 AM
