Results 1 to 10 of 19
Thread: 525i help needed please !
    Default 525i help needed please !
    E34 525i 2.5 24v DOHC.
    The car starts and runs perfect most of the time.
    Every now and then after it has started in the morning it will run fine and then suddenly become sluggish.
    Pressing and holding the throttle flat it revs to +-3000 and then drops back down, then up again and back down, it will not rev up.
    Also driving it like that is impossible, pulling off is nearly impossible.
    When I unplug the Air sensor it runs better but heavy on fuel, sometimes that doesn't even help.
    Anything to try or test ???
    Durban, South Africa
    Does the engine shut off at all after revving to 3K?
    And how does it idle in that state? should be around 750 to 900 rpm I think.
    I would try and test or have a look at your fuel pump. I'm having similer problems with my 90 525i and I'm replacing the fuel pump. Which will fix my problem. Another thing, when was your fuel filter last changed?
    Once the car is warmed up, will it run fine or not?
    Car: BMW 525iA.
    Engine: M20.
    Trans: Auto.
    Year: 1990.
    Agreed with Rob, change the fuel filters first, if still having problems hook up a fuel pressure guage to see where your at and go from there.
    Somedays it will be fine and not do it at all like today. Car ran beautifully today. Other days it just goes haywire.
    Will see if I can change the fuel filters this weekend.
    We thought it was temp related, when the car gets hot. But like today it was hot and nothing went wrong.
    Idling is a bit eratic when it does that.
    Switch it off and on a few times and it goes again.
    Other days you must sit and wait for it to come right, up to 2 hours sometimes.
    Might it be knock sensors or something ?
    Sep 2005
    southeastern, CT
    I had a similar problem on my 325i (same engine) and a new coil pack fixed everything. Do you have hesitation or bogging as well?
    If so you might want to check the coil packs/boots and plugs.
    Also might want to try cleaning the ICV.
    Also if the check engine light is on you should read the codes.
    89 535i/5
    90 535ia 158k
    90 Infiniti Q45 (sold)
    91 Sho (sold)
    94 530i/5 (sold)
    95 855 T5 @15psi boost
    Aug 2005
    Quote Originally Posted by gt90
    Not to hijack the thread. I have a hesitation when pressing on a gas pedal. The car does not react, you wait for maybe a second and it picks up. Or I release the gas, press it a little slower.
    You had the same hesitation and new coil packs fixed it?
    1994 520i with M50 engine, manual transmission and air conditioner.
    VIN: GG45422
    Sep 2005
    Goulburn Australia
    I agree that it sounds like a fuel starvation problem. I've had similar with cars other than my E34. The junk inside the filters moves around. Some days it wont bother you other days it will clog up. Starting the car a few times and jolting the fuel from rest through the pump will stir the junk up.
    Cheers
    Wingman
    '89 525i/A Exec 193000kms
    '94 Subaru Liberty AWD Wagon
    Looking for Merc 300TE
    NSW, Australia
    When I unplug the Air sensor it runs better sometimes but then it smokes and is heavy on fuel.
    Going to change the fuel filters and check the spark plugs and wires.
    Aug 2005
    Is it safe to unplug the MAF while the engine is running?
    VIN: GG45422
    Sep 2005
    Goulburn Australia
    It would appear that your O2 sensor is working then (I assume that it is black smoke). Is there a 'miss' anywhere?
    Cheers
    Wingman
    NSW, Australia
  1. 94 525i Help Needed... Won't Run
    By Disney in forum 5 Series BMW
    Last Post: 08-24-2006, 12:09 PM
  2. Instument cluster PLUG needed for 525i.
    By nariusb in forum 5 Series BMW
    Last Post: 12-09-2005, 10:57 AM
  3. Who needed GC coilover kits for 525i?
    Last Post: 12-07-2005, 11:20 PM
  4. What is needed for a tune up? 89 525i
    By misfortune in forum 5 Series BMW
    Last Post: 11-16-2004, 10:45 AM
  5. Looking at 1989 525i M20 - Advice Needed
    By BlueMonday in forum 5 Series BMW
    Last Post: 10-09-2004, 01:30 PM
