How good is your battery?
Low battery voltage will cause the trans program. For example, If you ran the radio too long while polishing the car with a weak battery could do it.
A lot of quick starts and stops such as moving the car around may affect it as well.
Perhaps the transmission electical connections are dirty or loose.
Originally Posted by
Hypr5
Hey guys,
The car (95 525i) got it's first trans program after a rebuild. 700 miles on it. The thing is it drives and shifts normal.
It didn't come on while I was driving, though. When I switched off the ignition, it did the "dong" and then read out trans program. I started it (no trans program on check control anymore..)took it for a short drive and it couldn't duplicate the problem.
Any ideas on what could cause this? It seems wierd that it didn't come on while driving.
