It should clear.
If it keeps up, check the plug to the sensor, it's down low so it gets crusty and needs some cleaning.
Hi All,
I had an engine oil low indicator, and sure enough, I was indeed a little down. I put in 1 L and it measured up fine, but when I started the car up (and the next few times, within 60 miles) I continued to get the low indicator on the dash.
Do I need to reset something, or could my oil really still be low?
Thanks for any help!
Thanos
It should clear.
I read thinner synthetic cleans it up...did for me.
de sludged your sensor
Thanks a lot. Will check sensor.
