Results 1 to 8 of 8
Thread: Installed 19# injectors
    Default Installed 19# injectors
    Well guys I installed Ford design 2 injectors today, and I noticed a considerable difference in idle, and throttle response. I took the car out for a test run, and came across a new Mini. Still has temp plate. Well needless to say, I was opening a can of whoop arse, and had a blowout at 120mph. Right rear tire was shredded. Put on the spare, and limped home.
    how did it handle when the blowout happened?
    Maryland
    I'm glad it was a rear tire... and I hope no one rats you out for reckless driving!
    Where did you buy the injectors? Evan
    To answer both questions, It handled very smooth. Running 235/40/18 Pirrelli P-zero nero's bilstein sports, and Bav springs. I purchased the injectors at a local salvage yard for $50. What a steal. My biggest problem is not having rear camber adjusters. Have a good place to get some?
    Jul 2004
    Montreal, Canada
    as per Mercedes Benz... a blowout in the rear is more dangerous than the front... more chance of a fishtail and loss of control.... you are pretty lucky!
    I had a rear go in an old shitbox at about 100, I saw the tire roll off the road into the ditch in the mirror and knew I was in trouble!!
    No control problems, but I had a super hard time getting the lugs off that wheels!
    ^°^ ><((({º>°°
    I would rather have a rear blow than a front. I can say now that the Nero's hold up pretty well at a highspeed blowout. I had a rear blowout in a van once, and it was a very scary feeling even at 50mph. I went to Portland a few years back, and took a racing class driving formula one cars. That was a awesome ride. Would recommend this to everybody to try.
    Felix the problem with your rear camber is that the springs are TOO low. I used these springs as my first spring (downgrade) and the front was unbearable so I got Eibachs. The Eibachs are higher in the back and the camber isn't bad at all.
    Jeff, I guess i'm gonna have to use eibach. Thanks for the info.
  1. Injectors
    By SilverFive90 in forum 5 Series BMW
    Last Post: 06-22-2006, 02:06 PM
  2. Injectors
    Last Post: 02-11-2006, 01:46 PM
  3. M60 Injectors
    By araine901 in forum 5 Series BMW
    Last Post: 08-02-2005, 06:32 PM
  4. M60 Injectors
    By kentish in forum 5 Series BMW
    Last Post: 12-07-2004, 11:27 AM
  5. 5.0L injectors
    By gacssean in forum 5 Series BMW
    Last Post: 06-11-2004, 12:56 PM
