Page 1 of 4 123 ... LastLast
Results 1 to 10 of 35
Thread: Its final - I cannot get crank bolt off
    PA
    Default Its final - I cannot get crank bolt off
    I used a piece of 1/4" steel flat bar, drilled a hole in there, grabbed a crank pulley bolt, threaded it thru and used the floor as a stop. Turned the bolt counter clock wise with 4' breaker bar, SNAP goes the bolt in the crank pulley end. Thinking they aren't bolts rated for that kind of force, I move to the flywheel end... put one in so that it stops against the engine stand/bar, SNAP goes that bolt too.
    Wtf do I do now.
    Big D says it was 600 ft lbs and he had to use 2 hands so whats your problem?
    3/4" impact gun, 3/4" socket.
    Remount the flywheel if it's not still in place, fab up a copy of the factory tool (picture should be in TIS -- check group 11, then should be somewhere around 031) or use the real mccoy. Edit: actually, the picture probably isn't in TIS -- can snap a few and give dimensions if I go in tomorrow. Or, find a ring gear with holes through it, find a large brass drift that'll fit through one of those holes and snug up against the block (assume you've got the pan off). Make sure it's a brass drift.
    It'll be off in two seconds that way...do it all the time.
    For torquing? 5 foot long 3/4" torque wrench
    best, whit
    PA
    Quote Originally Posted by lowell
    best, whit
    Pics of any of this?
    I have it on an engine stand, so flywheel won't fit
    all you need is a big D...lol, I miss that guy.
    PA
    a big what
    Honolulu
    Default A few feet of chain bolted
    to the crank and block will hold it tight while you break it free.
    Mar 2004
    You need to redesign your holder to pickup at least 3 or 4 of the 8mm(?) bolts in the front crankshaft hub. Bolts have to be tight also, if not then they'll likely shear also.
    I'd avoid trying to hold crank from flywheel end. Crankshaft is long and you'll feel the crankshaft deflect at these torques.
    Also, be careful you don't break your engine stand. These are large loads that you're applying to the unsupported end of the engine.
    Paul Shovestul
    Wtf do I do now.
    East Brunswick, New Jersey
    You are very screwed. I had the same situation on my 525i last summer. The twin mass was too thick so I removed it to fit the engine on the stand. On hind sight I should have loosened the crank bolt (318 ft-lbs?) in car but it won't help you now. I Jammed a big flat blade screw driver between two flywheel bolts trying to turn it. It damaged the lip of the end of the crank. Major disaster. I had to trim about 1/4" off the end by Dremel. See picture.
    Anyway, so how did I do it...Trying to remember now. Yeah, I opened the sump. Turned the block upside down. Then jammed a piece of 2x4 between the crank shaft and the block to turn the bolt loose. I think that's is your only hope now. There is no way to get eny other leverage without the flywheel on the stand.
    But you know if you have the engine in car, you can insert a punch of 1/4" diameter in the hole below the starter. Line up the engine at No.1 TDC, you can lock the crankshaft to the block and turn the bolt loose that way.
    '01 540it, 6/01
    '03 325i 5 speed, 9/02
    '10 535ix. 9/09
    '10 mini 6 speed
    '15 mini countryman 6 speed
    baton rouge, loserana
    if you have the pan off sticking a chunk of wood between the crank counterweight and the block works like a charm, otherwise it's build something that may or may not work/**** up the crank if you build it crapyly, i guess if the head is on you could try filling a cylinder with oil but that'd be messy, real messy if you got the valve timing wrong and filled it on the wrong stroke. if you build something bolt it to the back of the crank so you are using the larger bolts that are less likely to sheer unless you make something that uses all of the 13mm's on the front
  1. M50 crank bolt torque?
    Last Post: 03-18-2008, 10:06 PM
  2. Crank sensor problem: A note on Crank sensors
    Last Post: 01-30-2008, 07:18 PM
  3. final head bolt torque question
    By tjn in forum 5 Series BMW
    Last Post: 11-19-2004, 01:53 PM
  4. Water pump bolt broke, what type of bolt extractor?
    Last Post: 05-15-2004, 02:32 PM
  5. It's final, I'm outta here. Thank you to....
    By stan in forum 5 Series BMW
    Last Post: 04-28-2004, 11:53 PM
