EAT chip installed... Something wrong?
Well, I got it in yesterday and the install went fine. E34's notes were great and helped alot, but getting that upper board out took significantly more effort pressure than they led on. I thought I was going to break something. I finally popped it out though *WHEW* and the rest was easy.
The good news.... she fired right up (another big *WHEW*). I let her idle for awhile and went around the block. I have to say, I'm not as blown away as I wanted to be and I'm a little disappointed, so maybe I screwed up.
Goods:
Butter smooth idle
Butter smooth "electric motor" like, liniar power band. No hard spots.
Took that 2000 rpm "shake" right out of the motor.
And I *think* it pulls just a shade harder... cant really tell.
Bads:
The biggest annoyance, after reving up to 5K rmp or so and going to shift, when clutch engaged, rpm's actually raise 500 rpm and then s l o w l y comes back down making for awkward shifting.
The high rev when shifting and the slow rate of return is what is bothering me now. I will reserve my comments on the performance until I give the system time to adjust and also figure this out.
I was thinking, should I have disco'd the battery? I never saw that instruction, so I never did. Did I miss this step? Should I let all the sensors and whatnot recycle that way?
Any suggestions on how to dial in this chip would be great. Thanks tons
Scars are tattoos with better stories.
