Bump?
If you have an extra ECU...
I will pay postage - I need a 402 ECU for a BMW M50 525I non-VaNoS
Please PM mee ASAP.. I NEED IT SOON
-Artem
Bump?
or like the several i got when i entered (92 525i, my car) here:
http://www.car-part.com/
or by pm'ing rigmaster?
if i were you, i'd at least try to talk to mark d'sylva before paying out of your (rear end) for a specific number match, i'm pretty sure that many of the m50 ones will work with each other, but YMMV.
Well, the thing is - I just want to try it out first, if it works I can buy it form whoever sends me theirs... If not, or if you need it - I can send it back.
I just want to test my car without destroying a posibly good working ECU
-Artem
You can test with a 403 or 405, they are the earlier versions of the 402.Originally Posted by ArtemLepilov
What are you testing? Did you replace some coil packs?
MarkD
URL: www.dsylva-tech.ca
Or to put it another way, you want to see if your car destroys a perfectly good ECU.
Yea, I think SRR2 has some insight. And I think ole Arte needs a little reality check.
How would my car destroy an ECU? I replaced all the coils and the only possible thing that can be bad in my ECU is the transistor, which would go bad only if the coil shorted it out. NOW I REPLACED ALL THE COILS SO THEY ARE BRAND NEW AND THERE IS NO RISK IN THAT
WHY DONT YOU DO A LITTLE BACKGROUND CHECK BEFORE POSTING YOUR OPINIONS??? --> My previous posts for example??
-Artem
Res ipsa loquitur.
