bump
hi all! ive just bought a remus s/s exhaust for my bimmer but it looks like the boxes on the system are straight through, i was under the impression that engines needed a certain amount of back pressure to run properly! ive already removed the cat so do i need to refit my centre box or will the car be ok with this 'straight through' system? to clarify, my exhaust at present consists of straight through pipes to oem rearbox and the new system looks as if the boxes have no gas resistance at all! i still have the centre section in my shed. any comments will be appreciated.
bump
you dont need any backpressure as long as the O2 sensors are placed where needed, usually in US cars without cats it will read dirty and the DME cant compensate. Just a guess.
Correct me if I'm wrong but my understanding is straight through gives you improved top end at the expense of torque due to lowered back pressure. If this is a wives tell please let me know.
Cheers
Wingman
'89 525i/A Exec 193000kms
'94 Subaru Liberty AWD Wagon
Looking for Merc 300TE
NSW, Australia
Mostly true, but good exhasut systems are designed to provide the proper reverse-pulses for a good burn (and good power...). I'm pretty sure the Remus are of fairly decent quality and are not really just "straight through." The "box" is designed to resonate and exhaust the gases in a certain manner (otherwise they wouldn't bother putting it there...).Originally Posted by wingman
1995 540i 6-speed
3.45 LSD, 17" Style 5's, AC Schnitzer Steering Wheel, Momo shift knob
How could the cats affect the O2 sensor if the sensor if before the cats?
i have heard that it is a wife's tail depends on what lengths of pipes you use on your headers, there is tons of stuff on the web about that, but i think in terms of exhausts that is what determines your power band. as you tune the lengths so that the shock waves from the supersonic closing of the valves reflect and arrive at the correct time to help with "scavenging" during the exhaust stroke or something like that, there is alot on intake tuning haven't seen too much detailed stuff on the principles behind exhaust manifold pipe lengths. But it is similar to setting the lengths of the intake runners (in that it uses the shock waves)
it cant.Originally Posted by Alexlind123
The literature I've read suggests that the less back pressure the better. This is backed up by scientific study.
"Contrary to popular opinion, any exhaust back pressure harms performance. What increasing back pressure does do is dramatically quieten the exhaust."
Source
Ah yes i have seen that book before, good book. I concur i also wonder, do people think it reduces low end torque simply because it doesn't choke the engine at high revs thus the peak torque occurs higher, yet low down torque remains constant but the written down "peak torque" occurs at a higher RPM? and if you look in the same paragraph it mentions the tuned lengths of the exhaust manifold, which for an NA engine is critical. and they will affect low down torque (compare for example 4-1 manifold vs 4-2-1 manifold for a 4-cylinder)Originally Posted by BigKriss
