Results 1 to 8 of 8
Thread: Rough idle - after reaplced coils and fixed engine...
    Aug 2005
    Newton, MA
    Default Rough idle - after replaced coils and fixed engine...
    Is it possible that the exhaust is making my car idle rough? After replacing the coils, the car idles better and all, but - its still a bit rough, and loud too - exhaust? Its mounts are broken in the middle and the exhaust itself is broken... Central resonator is definitely broken, getting worse over time.. Im waiting for one of my friend to get a TIG welder, so I can weld a straight pipe to the cats, and replace them.
    Just want to know if the engine is still in fine shape and all... It seems to be better, but maybe i just got the placebo effect.
    -Artem
    Jul 2004
    Quote Originally Posted by ArtemLepilov
    -Artem
    now i recall my car sounding rough with bad idling when i accidentally connected coolant temperature sensor into the plug for collant gauge sensor and respectively the others.
    also - How is the air flow sensor doing?
    vacuum - leaks?
    deleted air conditioning
    Aug 2005
    Newton, MA
    Umm.. Im pretty sure everything is connected right. The problem can be a bad ICV, or something else? What would cause a rough idle?
    -Artem
    Aug 2005
    Newton, MA
    PS - The throttlebody screw is all the way out to the nut.. Would that do it?
    Why do you think you need a TIG welder to repair a stainless steel exhaust? You only need a mig welder, stainless flux, and gas. Pretty standard fare stuff.
    I'd be looking for vacuum leaks, bad coils (or fried DME resistor as a result of a bad coil), clogged or restrictive cat.
    best, whit
    Aug 2005
    Newton, MA
    Fried DME resistor... I remember someone tried to do that in previous posts, but I dont think there were any pictures or any sort of instrustions on how to do that.
    Im saying - hes getting a TIG welder, and he said he would let me use it, so I dont really care what type it is as long as it works for me.
    Im almost sure there are no vacuum leaks and coils are good.
    -Artem
    Aug 2005
    Newton, MA
    Also - by rough idle i mean - the car is shaking when idling, the idle itself is actually pretty good - its solid at about 750-800RPM It drops when i throw the trans into drive, but thats a whole other thing, or it may even be normal... i dont know.
    The engine starts normally. Also - does it have a cold start sort of a thing? Because it idles around 750-800 usually after starting it and going from ~a bit over 1k RPM to 800-750
    -Maybe this clarifies it for some people.
    West Palm Beach, South Florida
    Harmonic balancer, or fan blade unbalanced? If you have the tool, you can try to remove the fan and see if that clears it up.
  1. Replies: 23
    Last Post: 10-07-2013, 08:56 PM
  2. Replies: 6
    Last Post: 11-24-2009, 10:16 AM
  3. "Check Engine" rough idle after engine Shampoo??
    By Guelphguy in forum 5 Series BMW
    Last Post: 04-27-2006, 01:06 PM
  4. Replies: 7
    Last Post: 03-09-2005, 10:42 AM
