Unloader relays cut power to all but necessary electrical items when you are engaging the starter.
I can't give you specifics about injectors (though I'm sure someone will....), but IMHO, you don't need to use anything other than stock injectors unless you have made other engine mods AND you know what you are doing to take advantage of "bigger" injectors. Simply installing "bigger" Injectors is a waste of $$$ because the ECU determines how much fuel is injected into the engine anyway.
Bret.
