compensate for a 20% increase in the injector size. I wouldn't do it.
Originally Posted by nariusb
I have 1989 525i with m20.
There's info about this but only for the big six engine.
I need to replace my injectors and I can get the Ford Mustang 5.0 4.6 19lb # injectors for cheap.
Could I do it without messing up anything and what outcome should I expect. I'm using stock 3 bar FPR.
it compensates for it ok but unless you need the extra fuel id just spend the money getting your orignal injectors cleaned and tested/ballenced, the 19# injectors will screw up the readings for the mpg on the obc on the m20 but they didn't really do anything to my 535s reading. i have the 19# mustang disc type injectors on my 90 325is but i have several mods
I found a site saying:
"In order to ease the transition of any injector swap borrow a 325e fuel pressure regulator, rated at 2.5 bar versus 3.0 bar, and it will drop fuel flow by approximately 9%."
You can read it full here: http://www.teamdfl.com/bmw/e30/fuel/fueldflhtml.html
I do have porshe 2.5bar FPR to help ECM udjust.
Is this for real?
Originally Posted by winfred
Im looking to do the same with my M20 motor. My research (so far) has shown that a proper setup with 19# injectors should be used with an adjustable fuel press. regulator fitted with a gage, and an air/fuel ratio meter so that you can finely tune the fuel injection system to the ECU. Also, Ive read that "stage II" type injectors should be used, not "III". Not sure why, Im still investigating.
Ideally with larger injectors, you should also have more air getting into the engine so a M30AFM, bored throttle body and intake manifold porting/polishing is good to have. And of course a performance chip.
I think your Porsche FPR can work but you have to fit it so that the connections are sound and leak free. I dont know if Porsche and BMW share the same tubing and hose dimensions, if not then reducers/adapters are in order.
I ordered the Bosch book by C. Probst to further my understanding of the fuel injection systems -cant wait for it highlight it, cant wait for the summer time to begin the project.
Support your American Flag Merchant Marine
No BMW at this time, eyeing a 91 318iS. 00 Saab 9-5, 89 Bronco XLT, 05 Kawi Z1k, 00 Ducati 748S Bip
Yes, this porshe FPR is identical to 525i with 2.5bar pressure. I had it on already and the car ran good with stock injectors.
The web page, I quoted before, says I should use it to train or easyin the ECM and then go back to 3 bar FPR and the computer will udjust further.
This was done on 325i so I guess it should work on 525i.
I wonder if anyone has done this with their m20's?
Originally Posted by Kobe Diesel
i never bothered with the 2.5 bar regulator nor has anybody i know that's done the injector swap, just start it up and go for a good drive and let it adapt, every time you dissconnect the battery it will need to readapt
rated for 199 hp, the stock m20 produces 168hp, so the stock injectors are already sized 20% over what you need. With the 19lb you'll be approx. 40% over the stock flow. The dme has to shorten the injector pulse time accordingly to try and compensate for this to keep from making the engine too rich.
Too rich doesn't make power or efficiency. By using the ford injectors you get better atomization when they are used with the correct amount of on time, Injectors are more efficient when they stay on longer
With the lower pressure regulator, the better atomizing fuel injector that your buying doesn't work as well because higher pressures mean the fuel is atomized better making it burn more efficiently.
So to sum it up you go bigger injectors which have to cycle for a shorter time. Then you lower the fuel pressure so that they cycle longer but you affect the better atomization you get with higher pressures.
If you don't have something that pumps more air through the motor then the larger injector size is not a help its a hinderance. Have you put a header on it , or ported the head or larger valve sizes or done anything to require more fuel?
i found a calculator online a while back that said mathmaticly the stockers are good for around 180 but i suspect they would hold up a little further, i think most people think you can stack the advertised hp additions and beleave they need more fuel with just a chip, muffler and hot air intake
Originally Posted by Bill R.
