Originally Posted by
jippijak
same running issues i took the plat+4's out and put in oem bmw plugs from the dealership and its the same it only backfires when i acelerate from stop or if i speed up on the highway. it feels like its backfiring but if i steadily push the gas pedel its smoother. after letting it idle, i turned it off and removed the plugs and they all looked fine but the plugs for 5 and 6 were soaked in gas. why is there escess gas on the plugs could it be because the coils are not firing right or could it be the injectors not spraying right? has anyone else had these issues?
thanks in advance Jippi
What sorta engine... please fill out your profile...
That said... was there oil in the bottom of the plug wells?
I miss my e34
