Results 1 to 7 of 7
Thread: Have done repairs took shortcut ...
    Jul 2005
    South Africa
    Default Have done repairs took shortcut ...
    Referring to similar thread...
    "Have done repairs, car won't start"
    My repairs were to replace a damaged timing chain guide.
    Doing the job properly requires the engine to come out, the heads to come off, the lower sump cover and the upper sump covers to come off.
    Remove the timing chain covers, fix the chain guide,
    Reassemble.
    I didn't remove engine, I did not remove cylinder heads, I did not remove upper sump cover .
    I did manage to get the timing chain covers off, fix chain guide and re-assemble timing chain covers around the cylinder head gaskets and the upper sump cover gaskets ................
    BUT after testing everything from sensors to sparking to fuel supply I finally tested compression..................
    I have no compression on two cylinders, 8 bar on two cylinders, 7, 9, 9.5 and 10 bar on the rest when I should have at least 11bar on all of them ................
    So are there any ways in which I can correct this without removing my engine ? It's a speculative question as I'm pretty sure there's only one answer and it's not a nice answer................. so much for taking the short cut ?
    Jul 2005
    South Africa
    Possible to leak past rings only ?
    Is it possible that I've lost compression due to damaged rings ?
    How bad is this going to get !!!!
    Default Not to throw more fuel on the fire but the compression for the
    m60 motor should be 12 bars minimum
    I would almost guarantee that either you still have the cam timing off or you have bent some valves.. The other remote possibility is that its a nikasil motor and the bore is gone on some of them...
    [quote=revert]Referring to similar thread...
    Jul 2005
    South Africa
    Default 12 bar pressure
    Yeah thanks Bill,
    I phoned around a little and somebody said to me that "no compression" means more than a little leak - like the valves are all opening at the wrong times. So I agree and don't have a problem with the additional fire. Opened up again and now I'm busying rotating the crankshaft and checking the position of each valve.
    Firing order is 1 5 4 8 6 3 7 2 and back to 1. Having a little difficulty sussing out when valves are opening and closing since they're all doing their thing together. I had drawn up a diagram through the 360 cycle (x2) of the crankshaft and now I cannot find the elusive document. Anyway, trundling along some more.
    Jul 2005
    South Africa
    Default Tensioner, chain or normal ?
    I have the "tappet covers" off, the crankshaft set to TDC and I notice that the camshafts on the block with cylinders 5 to 8 are still in their correct position. But the cams for block with cylinders 1 to 4 are out by a few degrees.
    When I did the adjustments I also used the special tool that you wind into the chain tensioner slot up to 1.2Nm - I notice that my chain tensioner does not push the chain as much as the special tool. Either
    a) Is this typical ?
    b) The chain tensioner was replaced by the BMW dealership before I took the car away from them (lots of money and no progress .... ) so I'm assuming that they did actually replace it and that this little guy is supposed to not tnsion as much as the special tool. Maybe the tensioner needs replacing ?
    c) The chain is stretched and the special tool should not have been able to tighten the chain more than the replaced tensioner ?
    Or maybe I have a few too many bent valves
    Jul 2005
    South Africa
    Default CAREFULLY adjusted camshafts
    After repeating timng checks and this time being absolutely sure of the alignment of the cams and crank to TDC I came up with worse results:
    Compression results before and after re-adjusting
    Cyl 1 = 8.0 / 7.5
    Cyl 2 = 0.0 / 0.0
    Cyl 3 = 10.0 / 7.0
    Cyl 4 = 9.0 / 6.0
    Cyl 5 = 7.0 / 3.5
    Cyl 6 = 9.5 / 7.5
    Cyl 7 = 0.0 / 0.0
    Cyl 8 = 8.0 / 6.0
    What's the opinion: Stretched timing chain or bent valves ?
    How can I test to determine which it is ?
    Default Its not a stretched timing chain, its most likely bent valves, if you
    pull the valve cover on the cyinders that have no compression and rotate the engine so that cam is on the heel for that cylinder first for the intake, look and see if there is a space between the camshaft lobe and the hydraulic valve adjuster, if there is a gap then the valve is bent
    Quote Originally Posted by revert
    Cyl 1 = 8.0 / 7.5
    Cyl 2 = 0.0 / 0.0
    Cyl 3 = 10.0 / 7.0
    Cyl 4 = 9.0 / 6.0
    Cyl 5 = 7.0 / 3.5
    Cyl 6 = 9.5 / 7.5
    Cyl 7 = 0.0 / 0.0
    Cyl 8 = 8.0 / 6.0
  1. Just some minor repairs?
    By Ross in forum 7 Series BMW
    Last Post: 04-19-2008, 06:38 AM
  2. New to own car repairs
    Last Post: 01-31-2005, 05:39 PM
  3. Thumbs up on Heater Core Shortcut
    By Tder in forum Body & Interior
    Last Post: 05-09-2004, 02:32 PM
  4. Thumbs up on Heater Core Shortcut
    By Tder in forum 5 Series BMW
  5. Replacing Heater Core Using Shortcut
    Last Post: 05-06-2004, 06:04 PM
