I'm more than a little frazzled!!
Opened up guts and checked both camshafts on both sides with crankshaft and all my settings were spot on. So I thought maybe I should be able to hear my fuel pump and went and tested. After initially tracking the wrong relay (two similar relays) and getting all excited because at least I've now found problem with open circuit between relay and fuel pump fuse, I discovered the correct fuse and the reason why I don't hear the fuel pump buzzing is because the DME only switches the relay when you turn the engine over with the starter. After forcing the fuel pump relay closed I could hear both the fuel pump and the electronic box fan......
So now I'm up the creak without a paddle. Any other ideas other than dragging a dealer mechanic to my house ?
