Results 1 to 2 of 2
Thread: rough running
    Dec 2005
    south jersey, usa
    Default rough running
    1991 525i with 45k orig miles started running rough so i decided to change the plugs. the plugs i pulled out were worn and were not original plugs they were generic champion plugs. so i got new plugs, bosch and the car runs even worse then before. when i acellerate from a stop the car feels like it misfires amd there is a sort of a popping noise frome the engine. i assuming its a premature detenation. when the engine gets up to 3k rpm the sound dissappears but the tranny feels like it doesnt want to up shift. anf the cars at about 55-60 mph. when i changed the plugs i also changed the plug boot because the resistor values on them had a real broad range from 10k to 13k. the coils are the original ones that came with the car and i was told that the original coils were made by bremi so i got 6 bremi boots that had a resistor value of 1.8k. i suspect that one of my coils are bad, what are the signs of a faulty coil? is there a way to test the coils? or is it something else?
    thanks in advance
    Jippi
    btw: the bosch plugs i used were the f7ldcr plugs that the bmwe34.net site said was the original ones.
    exactly what plugs did you get?
  1. running rough
    By edward in forum 5 Series BMW
    Last Post: 05-16-2009, 10:30 PM
  2. m30 running rough won't run idle fix
    By clarkstreet in forum 7 Series BMW
    Last Post: 02-28-2009, 09:08 AM
  3. Rough running engine and need help
    Last Post: 01-25-2007, 11:23 AM
  4. Running rough when cold
    By Trevor in forum 5 Series BMW
    Last Post: 12-04-2005, 09:59 PM
  5. Rough idle after running out of gas?
    By wengenstein in forum 5 Series BMW
    Last Post: 11-06-2004, 05:18 PM
