Results 1 to 2 of 2
Thread: '89 525 ls clucking sound rear on low speed turns
    Apr 2004
    Default '89 525 ls clucking sound rear on low speed turns
    '89 525a limited slip, 150k has clucking sound rear on low speed turns and less loud occasionally on straight away. Sounds almost like loose lug bolts, but lugs are tight.
    May 2005
    central coast nsw au
    get under the car, take the heat shielding off and grab the tailshaft near the centre bearing and give it a shake. is f its loose and makes the twitching/ clucking noise then thats it. Was the same symptoms on mine. hope this helps
  1. Radio turns on, but no sound?
    By rcbrown23 in forum 5 Series BMW
    Last Post: 08-21-2007, 04:29 PM
  2. clunking sound in rear at 25 mph.
    By adamhop in forum 5 Series BMW
    Last Post: 02-15-2007, 01:36 AM
  3. 540i 6-speed Touring, Eisenmann sound pdf file
    Last Post: 10-31-2005, 10:27 AM
  4. loud clucking noise
    By yolusola in forum 5 Series BMW
    Last Post: 10-05-2004, 02:35 PM
  5. Wife turns 30, E34 turns heads...
    By billb in forum 5 Series BMW
    Last Post: 06-14-2004, 04:28 PM
