Results 1 to 10 of 15
Thread: 1995 525i (US) TRANS PROGRAM HELP!
    Unregistered Guest
    Default 1995 525i (US) TRANS PROGRAM HELP!
    Long story short - I have checked all of the most common web pages for this issue (Bruno's is a big help but did not fix this particular issue) - but - I still get intermittant trans prog message on the display which started this Xmas. The transmission has always worked fine and still does even when the message is displayed.
    So far, the following has been done (at Dealer):
    (Transmission was rebuilt by dealer 20K miles ago)
    1) Replaced the circuit board that controls the dash instruments (cluster) - no effect...
    2) Temporarily swapped the check control module with known good - still no change
    3) Swapped out the transmission control unit - no change
    4) Pulled the pan off the tranny to inspect for internal wiring flaws/shorts - nothing
    5) Ohmed out all the cables and put it on the CAN analyser - no issues found
    6) Battery is good (and on charger) when testing (fails either way)
    7) The transmission switches (A-M mode and position switch) have been cleaned and seem to be okay
    This is where we are now stuck!!!! This is so frustrating - anybody have any suggestions?
    (I did see the post about checking the 50A fuseable link which we will check)
    Makes me want a Mazda again... Well maybe a 328
    Scott
    Hi Guest.
    So apart from the TRANS PROGRAM message, are there any other symptoms?
    Cheers,
    Trevor (Sydney)
    E46
    00' 323iA (70,000 kms)
    Unregistered Guest
    Quote Originally Posted by Trevor
    Hi Guest.
    No other symptoms - the transmission always works flawlessly. The Trans message is accompanied by the bell but the car works fine. (Trans does not go into limp mode!)
    Scott
    I have experienced a similar problem. I am planning to change the tranny speed sensor to see if it would make a difference.
    Default Have you already seen this bulletin?
    Quote Originally Posted by Unregistered
    Scott
    Atlanta, GA
    Default Where the hell you been Bill, we missed you like mad.
    Yup. I'm not afraid to say so.
    Last edited by G Feller; 03-17-2004 at 03:11 PM. Reason: don't need that diagram twice
    Colorado
    Ditto that! had questions,couldn't email or PM.
    Mike
    mikey535im...........1991 535im , Schwarz , H&R/Boge gas ,17" Style 10's , EAT Chipped :eek: Colorful Colorado
    Miami Lakes, FL USA
    Default Prolly gettin' his teeth fixed............
    :d
    There is nothing worse than a brilliant image of a fuzzy concept. -
    .............Ansel Adams
    Apex, NC
    Bill, you scared us! You okay?
    Scott
    '11 TSX Sport Wagon
    '00 328i
    '78 MGB
    '08 Saab Aero
    Unregistered Guest
    I have not seen this before but will now - thanks much!
    Scott
  1. 95' 525i "Trans Program" error
    By 50volvo in forum 5 Series BMW
    Last Post: 08-19-2008, 06:13 PM
  2. 1992 525i trans program new tranny
    By 85rx12a in forum 5 Series BMW
    Last Post: 01-28-2008, 05:05 PM
  3. 1995 525 Trans Program Question
    By tclucas in forum 5 Series BMW
    Last Post: 02-01-2007, 04:15 AM
  4. Trans Program
    By acidmale69 in forum 5 Series BMW
    Last Post: 05-13-2006, 05:38 AM
  5. 1995 530i trans program
    By zellars in forum 5 Series BMW
    Last Post: 03-06-2006, 01:05 PM
