Results 1 to 4 of 4
Thread: Drivers side door wont unlock with key
    Dec 2005
    Default Drivers side door wont unlock with key
    My drivers side door has suddenly stopped unlocking with my key.
    It locks just fine with the key. It locks/unlocks fine from inside the car pulling/pushing the lock thingy. It unlocks fine if I unlock from the passenger side.
    I have tried synchronizing the door locks. I looked at the fuses under the rear seat and didnt see any that were blown.
    Anyone have any ideas on what happened, or what it will take to fix?
    IIRC there are a couple micro switches that are activated when you turn the key, I'd guess one is dirty or bad, replace those and the problem should go away.
    Aug 2005
    West Portland, OR
    Hmm, I have the same problem but it coems and goes except I can't LOCK. Like I said sometimes it works but its always in these long periods for like 3 weeks where it won't work and mysteriously it works again.
    Also, it seems to lock..and then unlock itself other times. Usually these things are not happening at the same time except once and a while, is this related to those switches also? I have been hoping that I don't have to get new locks...
    -Charles
    EuroLux:. Private Detail
    Jun 2005
    Cleveland, OH
    Quote Originally Posted by CharlesAFerg
    -Charles
    Yeah.. chances are good it's the micro switchs...
    I miss my e34
  1. Replies: 1
    Last Post: 05-22-2009, 11:10 PM
  2. Driver's side door will not unlock! Button seems stuck
    By Dick Schneiders in forum 5 Series BMW
    Last Post: 11-29-2004, 10:41 AM
  3. E36 Drivers Side Door
    By civiltp in forum 3 Series BMW
    Last Post: 10-25-2004, 02:29 PM
  4. Help! Drivers side door metal is ripping
    By Russ in Seattle in forum 5 Series BMW
    Last Post: 02-15-2004, 09:26 PM
